Author Topic: Help with Maleable Iron Texture / Material  (Read 3472 times)
Offline Stuartwood999
« on: November 12, 2018, 05:57:29 am »
Hi.
I'm a newbie with keyshot and I am having trouble getting a realistic looking texture for Malleable Iron. I have found several cast iron type textures but none of them seem to come close.
I have found the attached rendered image on google and its pretty much exactly what I want to achieve.
Can anybody give me some tips or point me in the right direction please.
Thank in advance.
Stuart
Online Eric Summers
Re: Help with Maleable Iron Texture / Material
« Reply #1 on: November 12, 2018, 11:41:20 am »
Hi Stuart,
Welcome to the forum! :) We all started somewhere and this forum is a great place for help!
I didn't have a chance to try this, but it looks like you might be able to achieve that look using one of the Noise textures (Fractal or Texture) for your bump map. If you have KeyShot 8 Pro you could use the texture and displace your geometry with it.
« Reply #2 on: November 12, 2018, 11:53:33 am »
Yep. Lightings going to be a critical factor there as well, to be able to see the depth of the texture. Can surely be done, take a look at some of the MoldTech bump maps too. Scaled correctly they might get you there.
Online Eric Summers
« Reply #3 on: November 12, 2018, 01:08:05 pm »
I thought about that too, especially some of the ones from the Downloads section on the KeyShot website. The only catch with those is that since they're image based, you might see texture seams.
« Reply #4 on: November 12, 2018, 01:23:55 pm »
Yeah, and the mapping might get a bit weird too. Procedural would def be the best way to do it now that I think of it. I thought the mold-tech ones were seamless? I havent' played with them much.
Online Eric Summers
« Reply #5 on: November 12, 2018, 01:46:16 pm »
I use them a lot and now that I think about it, I've never run into an issue with them. But I've never used any of the more "dramatic" ones, so weirdness might just blend in. But it would make sense that they would be seamless. I like to avoid image based textures if I can just because I like the control I get with the procedurals.
« Reply #6 on: November 12, 2018, 02:39:24 pm »
Thanks for the pointers.
I shall spend some time experimenting and report back.
Stuart
« Reply #7 on: November 13, 2018, 07:09:46 am »
Hi
Thanks so much for the pointers.
I located the Mold-Tech Stipples materials made some modifications after watching some more keyshot videos and here's the result.
There are a few areas to look at, but i'm really happy.
I need to look at a ground plane / work surface to sit it on next but I guess that's just adding some model geometry.
Thanks again.
Online Eric Summers
« Reply #8 on: November 13, 2018, 07:43:05 am »
Nice! That's looking really good.  :)
« Reply #9 on: November 13, 2018, 08:15:24 am »
Thanks Eric.
I have solved my base geometry question by adding a ground plane. I love this software !
« Reply #10 on: November 13, 2018, 09:14:57 am »
That's looking really good!
Offline RRIS
  • Total likes: 5
« Reply #11 on: November 19, 2018, 01:46:25 am »
If you want some more color variation you can use the same bumpmap for diffuse color (maybe with a color adjust utility inbetween). And maybe even better, you can vary the roughness with that as well.
« Reply #12 on: November 20, 2018, 01:34:21 am »
Thanks, I'll try that too. :)
