Delete multiple environments??
Started by dan_tyce, November 26, 2018, 05:17:37 AM
dan_tyce
We have imported numerous keyshot files into 1 master scene, and this seems to have created a crazy number of duplicate environments (literally over 1000).  Is there a way to delete many or all environments at once?  The Environment tab only allows one at a time to be deleted.
Thanks for your help
You can try to put every part in another model set (linked materials) and export this as a new scene.
So you'll get only geometry without cameras and environments.
Hope that helps
 I'd find the one you want to use, lock it, and just rapid fire on the delete key. Unfortunately the arrow keys don't work in that pane to move up or down the list, so you'll have to get good with the mouse too.
dan_tyce
