Author Topic: Rendering Clear Plastics with Backplate  (Read 1738 times)
Offline topsecretagent
« on: December 11, 2018, 09:20:32 pm »
Hello!
Could someone please help explain why clear plastic materials are showing a dark area (on the right side) when using a backplate image? This doesn't happen when rendering on a color background.. adjusting ray bounces does nothing. Global illumination is on.. I can't seem to find any information regarding this issue! Anyone else encountered this?
Any help appreciated!!
Offline kiarash.tamizkar
Re: Rendering Clear Plastics with Backplate
« Reply #1 on: December 13, 2018, 06:20:51 pm »
it is because of thickness of glass and Fresnel effect ,its normal
Offline RRIS
  • Total likes: 5
« Reply #2 on: December 17, 2018, 02:25:53 am »
Does it look any different when changing the material to solid glass?
Offline Will Gibbons
« Reply #3 on: December 18, 2018, 08:04:56 am »
It's because they're reflecting the dark areas in your HDRI (a backplate doesn't get rid of HDRI reflections). You could use this image as the background of your HDRI and then the dark areas would be colored to match your HDRI instead.
