Author Topic: Number Fade - Question  (Read 2275 times)
Offline kyozon
« on: February 28, 2019, 09:20:39 am »
Hello there!
I wanted to know if there is a way that I can add a Number Fade node to the Shift in the Color Gradient Node. This should allow me to change between my Colors for a LED in an animation.
Offline Eric Summers
Re: Number Fade - Question
« Reply #1 on: February 28, 2019, 09:42:05 am »
Drag the output from the Number Fade onto the Color Gradient node and you'll have the option to connect it to the Shift.
What about using a Color Fade node for the color change instead of using a Number Fade to drive the Shift?
Offline kyozon
« Reply #2 on: February 28, 2019, 11:24:29 am »
Thank You!
I just tested the Color Fade Node and it turned out to be even better results!
« Reply #3 on: February 28, 2019, 12:41:45 pm »
Happy to help!  :)
