lagging issues on a threadripper setup
Started by jet1990, May 20, 2019, 08:55:50 AM
jet1990
Hi all,
Im currently using my new workstation which has the 32 core threadripper along with a 5gb p2000 GPU and 64gb RAM.
Ive noticed when navigating scenes within keyshot that as im panning/ rotating in the realtime view its quite laggy and stuttery.
Granted using performance mode would be a better option but i cant help but feel i shouldn't be experiencing this sort of lag with my setup.
the scenes im using aren't particularly complex.
any ideas on this? is there a tweak-able settings in preferences?
thanks
sleby
Have you tried the old trick - stepping down the cpu usage to something like 94%?
Which version of KeyShot? Adaptive performance mode (added in KS7) should automatically enable performance mode when navigating the camera if your FPS drops below a certain threshold. I have the same chip at home and don't experience lagging. That said, I do not leave it at 100% cpu usage.
jet1990
im using V8.2... I currently have mine set to 88% usage which is 56 cores according to this.
Esben Oxholm
#4
Do you by any change have curves adjustments active in the photographic image style?
I've experienced (at least in prior version of KeyShot 8), that it could affect the performance of navigating and such.
// edit: haha, I have written KeyShot 8 ) (without the space between 8 and )) above and it turns the 8 and ) into 8)
jet1990
I do Esben. I turned it off and it appears to increase performance. Any idea why that happens?
Esben Oxholm
Quote from: jet1990 on May 30, 2019, 06:28:45 AM
Nope. It happened all the time in some of the early beta versions and I know it was taken care of, but sometimes it still occurs. Don't know why.
