Author Topic: HDR light studio + Keyshot....practice  (Read 13452 times)
Offline Seggy
Re: HDR light studio + Keyshot....practice
« Reply #15 on: September 29, 2011, 12:53:21 am »
Hi Zander
Mark here from HDR Light Studio... please email me your bip file ([email protected]) and I'll set something up for you showing you how to do this, and post it back on this forum.
I think we can do everything you need without anything in the scene but the rings themselves.
I got your email... but I just saw this posting too... maybe other people will be interested in how I'd tackle it in HDRLS.
Regards Mark
Offline Seggy
« Reply #16 on: September 29, 2011, 08:59:30 am »
I decided not to wait for the jewelry model from Zander and kicked right into putting a little lesson together. It takes you step by step through a simple jewely lighting set up with a colored background, the effect you are looking for Zander.
Please do check it out here: http://www.hdrlightstudio.com/lesson/keyshot_jewelry_step_by_step
Thanks for the rings model.... I'll also knock up some lighting for that model also and share my results here.
Regards
mark
Offline Zander85
« Reply #17 on: September 29, 2011, 09:10:46 am »
Yes!!!!!!!!!!!!!!! Thank you Mark!!!!!!! ;D
Offline fario
  • Total likes: 0
  • www.mrconcepts.ch - industrial design and render
    • industrial design
« Reply #18 on: September 29, 2011, 09:13:08 am »
many, many many thanks!
it makes me want to buy this app.
Antoine
Offline Zander85
« Reply #19 on: September 29, 2011, 09:32:00 am »
I'd love to see what you can do with the rings I sent ya.
Offline Seggy
« Reply #20 on: September 29, 2011, 09:34:12 am »
Now with your rings.
This took about 10 mins fiddling around.
A good idea is to import a floor square and make it a glass material... you'll get far more realistic reflections than using ground reflections from KeyShot.
But it will cause complications with lighting because this glass will see all the lights too. If I get chance I may pop a floor in and see what it looks like.
Happy to help.
Offline Seggy
« Reply #21 on: September 29, 2011, 09:58:58 am »
The floor worked out pretty well as dielectric material with a bit of roughness, using IOR to change reflectivity.
Offline Zander85
« Reply #22 on: September 29, 2011, 10:07:30 am »
Wow thank you so much for all the help. Really makes my life easier. I really appreciate it Mark thank you.
-Zander
Offline Zander85
« Reply #23 on: September 29, 2011, 10:43:21 am »
I am following along with your tutorial right now and when I came to step 5 it says "make the light solid and lower the brightness to zero", but there is no brightness dial so I am assuming you meant the "dark" button which makes the light black. Am I correct?
Offline Zander85
« Reply #24 on: September 29, 2011, 10:47:11 am »
Oh never mind I see that you meant the wattage.
