Author Topic: Unable to import .alembic file in Keyshot. What to do?  (Read 14798 times)
Offline brahmzxc
  • Jr. Member
« on: June 15, 2019, 12:24:08 am »
I am unable to import this .abc file .
I have created this animation in blender with animation nodes.
I have also attached the .abc and .blender file.
Can anyone help me with issue, that what I am doing wrong here.
« Last Edit: August 22, 2019, 03:36:00 pm by Bruno F »
Offline brahmzxc
  • Jr. Member
Re: Unable to import .alembic file in Keyshot. What to do?
« Reply #1 on: June 15, 2019, 12:27:59 am »
And yes while installing keyshot I selected for "Only Me" not for "Anyone on this computer"
Offline INNEO_MWo
« Reply #2 on: June 15, 2019, 04:54:08 am »
For everyone who isn't allowed to install "only for me", can use KeyShot 7 to import the alembic file, save the bip and work on it in KeyShot 8. That is an improved solution!
Hopefully we get an update without this bug.
Offline brahmzxc
  • Jr. Member
« Reply #3 on: June 15, 2019, 05:33:57 am »
Hey Mwo, did u opened the file I have attached, I mean that can we import this type of animation in keyshot?
Offline INNEO_MWo
« Reply #4 on: June 15, 2019, 06:18:34 am »
No, until you asked for. I am no Blender user and I wasn't capable to export the alembic file right. Might be the turn for the Blender experts.
I can export it as fbx and can import the mesh in KeyShot 7 and 8.
Sorry - I out!
But I wish you good luck!
Offline Eugen Fetsch
    • www.camomiles.de
« Reply #5 on: June 15, 2019, 11:34:30 am »
You need to check the "Curves as Mesh" check box during the alembic export in Blender. Your current alembic file contains just the bezier curve without geometry/thickness. KS cannot read that.
Offline INNEO_MWo
« Reply #6 on: June 15, 2019, 01:18:18 pm »
Thank you Eugen.
I‘ve tried that, but without success. I’ve started learning Blender today.
Offline INNEO_MWo
« Reply #7 on: June 16, 2019, 08:46:14 am »
OK - here we go.
I added a solidify modifier to the curve and exported it as the attached alembic file. Maybe I added to many options? - But finally KeyShot 7 and 8 (for all installation) was capable to import the mesh.
    • www.camomiles.de
« Reply #8 on: June 16, 2019, 10:18:52 am »
OK - here we go.
There are different ways to get thickness on curves. 1st is to use the solidify modifier, 2nd is to use the depth parameter in curves properties. So, there is no right or wrong. You can even use both and create a pipe ;)
P.S.: You're entering the rabbit hole my friend and you'll have a lot of fun in this new world ;D @Marco.
Offline brahmzxc
  • Jr. Member
« Reply #9 on: June 16, 2019, 11:10:01 pm »
You guys did a great job, I am finally able to import this is Keyshot 8 but the problem is there is no animation, only the spline is being imported. :'( :'(
    • www.camomiles.de
« Reply #10 on: June 17, 2019, 03:39:23 am »
Did you scroll through the timeline - I have no issues with the import.
Offline INNEO_MWo
« Reply #11 on: June 17, 2019, 04:37:14 am »
Hello (from the rabbit hole).
Are there issue with the nodes in Blender? If I open the original blend file - hm - see it in the attached screenshot.
Otherwise an animation can be transferred to KeyShot with the "deforming mesh" option within the import dialog!
    • www.camomiles.de
« Reply #12 on: June 17, 2019, 07:29:25 am »
You're diving too deep for a beginner Marco. ;D
The issue is caused by a missing add-on "Animation Nodes". You need to install it first, to run the animation.
Animation nodes is an advances feature (IMO). I can give you a beginners crash course in Blender first, if you like. Let me know.
Offline INNEO_MWo
« Reply #13 on: June 17, 2019, 07:33:05 am »
Thank you Eugen for the offer. I appreciate this. But currently once a month with YouTube help I will take a look into it.
The goals are only some animation stuff with physics to compensate the things our CAD won't do or probably so UV unwrapping till KeyShot is capable to do this.
C u soon!
« Last Edit: June 17, 2019, 07:42:36 am by MWo »
Offline brahmzxc
  • Jr. Member
« Reply #14 on: June 17, 2019, 08:43:36 am »
Hey Comomiles,
I imported the .abc file that was attached by MWo and checked the deformable mesh.
But still you can see there is no frames in the timeline.
