Author Topic: .obj & .3ds import problems  (Read 8866 times)
Offline Tbird
« on: September 27, 2011, 05:14:43 am »
I am trying to import a model from TurboSquid as either a .obj or .3ds.   The model is supposed to have the body separated into separate components doors, hood, fenders etc.  When I import it the body is all connected. I am not a modeler so please reply in laymans terms as to a possible solution.
Offline w.wolf
Re: .obj & .3ds import problems
« Reply #1 on: September 27, 2011, 06:28:23 am »
If the model is really have separate bodies, then it's easy ...
Import the model to KeyShot, click on Options or double click the model then go to the Scene tab, you'll find a small arrow next to your model's name, click on it, probably other arrows will appear so click on each on ... then when you're finished press Ctrl+A to select all ... right click and Unlink Part ...
If you don't see any arrows then the model is actually one body ...
I hope that helps and I am sure there's a faster way but I usually import my models already separate ...
« Last Edit: September 27, 2011, 06:44:26 am by w.wolf »
Offline Deziner
« Reply #2 on: May 26, 2013, 11:39:47 pm »
Thanks w.wolf, I was facing kind of a similar problem and your comment helped..... :)
Offline TpwUK
« Reply #3 on: May 27, 2013, 12:50:02 am »
Hi Tbird - When you select the model to import, try show settings, then material at the bottom - Keep individual parts, then group by objects, if the model is indeed layered then you will have lots of parts top play with
HTH - Martin
