Ford mustang+ VDB
Started by kamran Rahmani, August 08, 2019, 02:06:02 AM
kamran Rahmani
Hi everyone, well this week i learned somehow how to work with vdb volume textures, and just wow!.what a great marvelous thing it is to use them. So i decided to use them in a scene. Can someone tell me how can i find more vdb files.? Cause They are marvelous . Hope u enjoy the scene .
Zeltronic
Hi, you will find some free vdb files easely with google here for example : https://www.openvdb.org/download/
you can also create your own with houdini or other software that manage vdb.
kamran Rahmani
Quote from: Zeltronic on August 09, 2019, 04:50:47 AM
Hi..thanks for your help.gonna check it soon :)
Do vdb files contain animation format (as i heard houdini helps you animate objects) and are they useable in keyshot ?
Josh3D
Nice, Vernal! Smoke looks dope :) Drop those tires into the ground a tad and you'll add some weight to the auto. Other than that, looks TIGHT. Hope to see some more angles and detail shots!
Zeltronic
#4
Of course you can use vdb file create in houdini with keyshot without any trounble as it is a standart all vdb can be use in keyshot.
