there is difference between my real time view and cpu render
Started by shayansep, December 12, 2019, 05:13:25 AM
shayansep
i was rendering a solitaire diamond ring in keyshot 9. when i hit the denoise button on the top of the screen it denoises the model really good in 25 secs but when i render the window with cpu the result of denoise is not the same as the denoise in real time window even after 5 mins of cpu rendering. first of all things like gamma and brightness works simultaneously as it renders but denoise only works at the end of the process and i have to uncheck it and then check it again to work which is weird and even after 5 mins the result is not the same please help me if you can
thank you
first picture is my realtime view window after 30 secs
second one is cpu render after 5 mins
Justin A
This topic will be locked due to inactivity.
If you still need help on the matter please create a new thread or contact Support@luxion.com for more assistance.
Thank you
