Move Tool - No Scale Option or Dialog Box
Started by Daimondo, January 08, 2020, 12:28:44 PM
Daimondo
Just upgraded to KeyShot 9 (ZBrush to KeyShot) and I'm having issues with the Move Tool. Apparently no dialog box appears when I select an object to move. Further, the Moving Tool is only for moving or turning an object - not for scaling. Of course if I had access to a dialog box, I could simply check Scale. Any help or suggestions would be welcome.
bharris
You can try going to Workspaces on the toolbar and changing to a different one. Or select Manage and try to Reset Default Workspaces.
Daimondo
Thank you for the suggestion. I can only use the Compact Workspace in order to change the scale, via the Move Tool at the bottom left.  I'm still wondering, however, why the Dialog box still isn't appearing for the Move Tool in any Workspace format.
