sending file over via bridge from Zbrush resizes Keyshot
Started by wayneheim, January 18, 2020, 07:46:40 PM
wayneheim
It's super pain in the butt. When I'm working in Zbrush and sending a file over to Keyshot..... the keyshot window resizes itself to full screen. I constantly have to keep resizing keyshot back down so I can have both on screen at the same time. It used to just update what was in the keyshot window. Hopefully this is an easy fix.
Pretty please!
Wayne
Hi Wayne,
I can confirm the issue.
Next up is figuring out if it is a fix on the KeyShot or 'ZBrush to KeyShot Bridge' side. It seems the KeyShot scene resizes to the ZBrush document resolution.
Update:
We looked at this and apparently the current behavior is intended and has in fact been requested by Pixologic.
The behavior hasn't changed since KeyShot 5 either, by the way.
If you want this changed, then your best bet will be to yank Pixologic's chain.  :)
