Author Topic: EXR files saving again when noise reduction is enabled for render.  (Read 1680 times)
Offline wayneheim
When rendering with noise reduction, the exr files are saving again. I believe in 9.1 these were automatically deleted.
Wayne
Offline Sune
  • Global Moderator
  • Jr. Member
  • Total likes: 8
  • Product Owner - Import, export and plugins
Re: EXR files saving again when noise reduction is enabled for render.
« Reply #1 on: January 21, 2020, 02:41:34 am »
Hello Wayne,
We are not able to reproduce this in 9.1. Can you share your process so we can find the bug?
Offline wayneheim
« Reply #2 on: January 22, 2020, 09:38:41 am »
I'm using build 9.1.77. Ok, a little more digging. Apparently if you open up a document that you previously made using 9 and rendered using noise reduction, the diffuse and normals stay checked marked as if you actually picked them. Unchecking them keeps it from saving the file. I assumed they needed to stay checked as in the past in order to use noise reduction. A bit confusing.
