Author Topic: Split Fillet Faces  (Read 232 times)
Offline Don Cheke
  • Newbie
  • Total likes: 5
  • Provider of Comprehensive TurboCAD Tutorials
    • Textual Creations
Split Fillet Faces
« on: February 18, 2020, 08:24:14 am »
Is there no way to split surfaces from a filleted box like the one in the example? I can apply materials in TurboCAD to the selected faces but in order to maintain the material structure I have to export out in 3dm format. Trouble with that is I can't always get the tessellation resolution that I want and there is no setting to increase it once it is in KeyShot. IF I export in stp which gives me  the resolution, I loose the materials and I can't split object surfaces in KeyShot
Offline TGS808
Re: Split Fillet Faces
« Reply #1 on: February 18, 2020, 10:16:51 am »
Have you tried dialing down the splitting angle number? Take it down to 20 and click on one of the flat planes to see if you can get a separate selection from the fillets. If that's not enough, go lower.
Offline Don Cheke
  • Newbie
  • Total likes: 5
    • Textual Creations
« Reply #2 on: February 18, 2020, 12:07:42 pm »
Thanks for the input. I needed to retessellate first and then change the splitting angle to 1 and it worked well for this situation. This is just a doodle today, while experimenting.
Offline TGS808
« Reply #3 on: February 18, 2020, 12:42:32 pm »
I'd say it worked perfectly.  :)
