How to not get patterns in textures
Started by figure1a, February 22, 2020, 10:31:53 AM
figure1a
When I use textures, I keep getting patterns. Attached is the Asphalt material from KS which looks like I did a bad cloning job in Photoshop. If I use the stone material, it looks like Minecraft. How do I tell KS to vary or alter the pattern so it doesn't make a distinct repeatable pattern?
Eric Summers
What is the scale of your texture? It looks like it might be very small, which could be the reason the repetition of the texture is so obvious. Otherwise I'd look into a procedural asphalt texture, rather than an image based texture.
figure1a
Quote from: Eric Summers on February 24, 2020, 11:08:12 AM
Don't recall the scale but the area is large so no matter what size I make it, I'm going to see a pattern. I'll look in to the procedural asphalt texture. Thanks!
