Author Topic: Morph animation not working  (Read 276 times)
Offline crea8ivemind
« on: March 24, 2020, 03:30:52 am »
Hi, my 3dsmax animation file have morph animation. When I export .FBX and recheck in 3DsMax, its working fine. But the same is not working in Keyshot 8. Any solution?
Thanks in advance.
Offline Eric Summers
Re: Morph animation not working
« Reply #1 on: March 24, 2020, 07:34:23 am »
You'll need to export an Alembic (.abc) file to bring an animation from 3DS into KeyShot.
Offline richardfunnell
« Reply #2 on: March 24, 2020, 10:53:39 am »
Actually, the best solution should be the 3ds Max plugin. You can find it here: https://www.keyshot.com/resources/downloads/plugins/
The plugin supports deformations without needing to export a neutral file type.
Offline eden55555
« Reply #3 on: September 15, 2020, 05:20:33 am »
Thanks in advance.
In the Thumbnail pane on the left side, click the slide that you want to apply a transition to, which should be the second slide you added the object, picture, or words you'd like to apply the morph effect to.
On the Transitions tab, select Morph.
