clown pass by part (not by materail)
Started by itsterril, April 16, 2020, 05:08:21 AM
itsterril
is there a way to do a clown pass by part and not by material assigned?  (i have a very heave part  count model and was rendering out some very basic color layouts, but now i want to do some post processing in photoshop and break it up by parts. It would take forever to unlink each material from each part)
itsterril
OK, never-mind. Looks like if you unlink material at the top level, it will break up every part into individual shaders too.... that should fix the problem
Otherwise you can use the render layer and put some parts on different layer?!
jogeshocp
You said perfectly, this way you can do it. Thanks for your query.
hazelviacpca
You can check the photoshop tutorial on youtube. Thanks for your post.
