floating window move option
Started by andy.engelkemier, April 29, 2020, 05:33:54 AM
andy.engelkemier
This is an issue with dual screen. Thank you for allowing floating windows, BUT please provide a way to move/resize them without being able to access the corners.
On dual monitor setups, if the setup Changes (like if I go home from work and now have different monitors) the corners can be entirely off the screen. I then can not move or resize the window.
I don't care what the solution is. It could just be a button you click and it looks at the screen resolutions and ensures all corners fit on screen. It could just be forcing floating windows to re-dock. I just don't want it to be resetting preferences if that happens.
I can't quite remember how I fixed it. I think it solves itself if you unplug one of the monitors maybe. Usually you can use Alt+Space, M.  As soon as you click your mouse the window snaps to frame. Or you can hit Win+Shift+arrow in many cases. But these windows are no windows frames, so none of those tricks work.
