Image Styles with Resolutions or at least aspect ratios settings kept.
Started by Aeonjoey, June 19, 2020, 05:18:40 PM
Aeonjoey
Hi there, I need to use the same model and output for multiple camera angles (e.g. ortho and perspective) and resolutions (e.g. 1:1 square and 16:9) with all the materials linked. Because I use one file, I have to rely on generating a thumbnail to remind myself each time i render to resetup my resolution using a preset, that is ignored by the render settings, and is not saved with the image style.
Since in Keyshot everything else is saved with a 'style' can the resolution (or at least aspect ratio) be saved with an image style? it'd help out immensely.
Higuchi
I'm totally with you! I'd like to change the aspect ratio depending on camera.
