GPU Errors
Started by LM6, October 01, 2020, 08:12:24 AM
LM6
I mentioned this in another post but no reply, could someone let me know why iam getting the following error
1. load a 3.5 gig  .abc file into Keyshot and turn on GPU =  no error
2. hide one of the bigger items in the scene tree and then un hide = error
Justin A
Based on the images you have supplied you are running out of Vram on the GPU card you are using.
When rendering in GPU mode you are limited to the VRam that the GPU has, so exceeding this will  cause this error and GPU mode will be deactivated.
LM6
Quote from: Justin A on October 01, 2020, 10:02:34 AM
Hi Justin ..
Thanks for the reply, if you look at the images more closely you will see that I am not running out of VRam, I have 11gig and the scene is 3.5 gig, I only run out of VRam when I hide then unhide something from the scene tree. Check the HUD in the images.
