Noise map banding at small scale
Started by Gestalt, November 26, 2020, 09:16:14 AM
Gestalt
Has anyone had this problem or know how to solve it? On a number of parts I get a banding effect with the noise map applied.
The below image shows the isolated noise map and you can clearly see the issue (different size banding on different surfaces).
Data came from Rhino import, tried custom OBJ import also. Normals ok. Keyshot V9.3 Pro, same issue in GPU or CPU mode.
Same issue wether Fractal or Texture noise map.
Also attached is the 'noise map as a bump map' illustrating the stretch and compression of the noise map that creates the bands. Clearly a mapping issue no?
Mods please let me know if I should report this as a bug?
Thanks,
tony_blenderman
tony_blenderman
#2
The issue surfaces when using low scale values and high bump values for noise texture.(making grainy plastic material for example)
I have exaggerated the issue in the attachment. Noise scale 0.1mm, depth 1.  Issue is not noticeable for depth values under 0.2
Re tessellating and  recalculating normals did not solve the problem.
Issue arises mainly on imported NURBS geometry. Inbuilt keyshot objects don't seem to show the same problem unless the sale value is made extremely low.
Changing scene units, Translating and rotating texture did not help.
Issue happens in GPU and CPU mode.
Nexus
Hello everyone, have similar problem. Keyshot 9 version.
Please text, if you solve this bug.
tony_blenderman
Hi Nexus, I found a workaround by translating and rotating the noise texture map. No specific angles or translation distances. Really annoying but fixed the problem well enough. Also please avoid using extremely low noise scales.
Hope that helps
jordan
Has anyone found a solution to this problem?
Happening in Keyshot 10 Also. Rotating the texture around feels like a band-aid approach to a potential core problem.
In the screenshot you can see the problem is happening on the bottom half of the object but not the top half, with the exact same material applied. Weird.
tony_blenderman
Hi Jordan. Try the bandaid approach! Also, do not go too low on noise scale value. Cheers.
