Can you include/exclude alpha in the same render?
Started by AdamAnt, February 23, 2021, 02:52:25 AM
AdamAnt
Hey guys
I need to render my shot with the background, and without the background..is there a way to do this with render layers or something?
Or do I have to add to outputs to the render que (with and without alpha checked?).. because i have trying to to this.. but im getting render errors when I do this...
and additionally, is there a way to get a black/white matte from the render passes? So that my object is white, and the rest black?
oh and finally.... what render passes do I need to check to get a composite view without the denoising applied? I know RGB is the only one that has the denoising...but I also need the 'final' picture without...so I can tune/blend the denoising myself...
thanks!
thanks!
INNEO_MWo
Hello AdamAnt
Put the top parent node of the scene tree to a render layer. That will give you a) the entire render with a transparent background (so you can toggle off alpha in render settings) and b) the render layer file is not denoised. Also you can check every render pass and look, what's useful for your post processes like the common ones, clown, diffuse, etc. You can use the occlusion render pass or render your own, if you need more control.
Hope that helps a bit
CheerEO
P.S.: written on a mobile device in short form
TGS808
Quote from: AdamAnt on February 23, 2021, 02:52:25 AM
You don't need to use render passes for this. Apply a flat white material to the object(s) in your scene. Set your environment background color to black. This will render a matte quickly.
INNEO_MWo
A clown pass has a black background. So you can quickly select this, invert selection and fill with white on another layer. No need for extra effort. The black background with flat white parts may worth when it comes to animations and post workflows.
There are many useful techniques depending on the needs. But can be solved with KeyShot.
TGS808
Quote from: INNEO_MWo on February 24, 2021, 01:14:41 PM
There's not really any extra effort. It takes minutes. It's more than worth it if you have DOF in the scene. Personally, I'm not a fan of selections from the clown pass and never use them. There's too great a chance for fringing on the edges where two colors meet which makes for imperfect selections.
mattjgerard
Quote from: TGS808 on February 24, 2021, 10:29:01 AM
Multimaterials and studios make this super easy to setup and retain your original setup as well
