Inventor animation to keyshot
Started by germannick, March 24, 2021, 04:57:21 AM
germannick
Quick question, because I never used .iam (inventor) files before. Can a native inventor animation be fully used in Keyshot, just like the CREO "mechanics data" in Keyshot? I would like to avoid to recreated the whole animation in KS again.
HaroldL
Run a forum search on "Alembic" file type. And check to see if Inventor can export to that file type. I think you need to convert your animation to an alembic file on export. KeyShot should import that file and retain the animation. Well, it used to, check with support to be certain.
germannick
HaroldL,  thank you for the hint. I`ll do my research into this direction. Many thanks
