Author Topic: Tri-Planer bind on an object?  (Read 3789 times)
Offline abedsabeh
« on: May 29, 2021, 09:45:45 am »
Hello everyone, is there a way to bind a tri-planer texture so it stays on an object during animation? I think I read it some where but I can't figure it out now :-) I appreciate any help thanks!
« Last Edit: May 29, 2021, 12:43:25 pm by abedsabeh »
Offline DriesV
  • Administrator
  • Total likes: 83
Re: Tri-Planer bind on an object?
« Reply #1 on: June 11, 2021, 04:22:10 am »
Hi Abed,
Can you give an example of the issue you are facing?
Are you seeing swimming textures on your animated models? What kind of animations?
Offline richardfunnell
« Reply #2 on: June 14, 2021, 09:16:24 am »
I ran into this when importing deformable mesh animations via .abc files; only world coordinates were respected resulting in textures floating in space as the objects moved.
My solution was to UV unwrap in the native modeling software and re-import. I never found a solution within KeyShot.
