Author Topic: Keyshot shutting down whenever trying to split object surfaces  (Read 3205 times)
Offline jet1990
as the title states, ever since upgrading to the latest version 10.2, whenever i try to split object surfaces the entire program crashes and closes.
Is anyone else experiencing this?
Offline TGS808
Re: Keyshot shutting down whenever trying to split object surfaces
« Reply #1 on: June 14, 2021, 11:57:07 am »
That doesn't happen for me. No shut down, no crash. It launches split object surfaces and lets me do it. I'm running KS on Mac, FYI.
Offline Synje Andersen
  • Technical Writer
  • Global Moderator
  • Newbie
  • Total likes: 2
  • Technical Writer, Manuals, Luxion
« Reply #2 on: June 22, 2021, 10:54:21 pm »
Hello jet1990,
We couldn't observe this on our systems. If you still have this problem, I suggest you contact [email protected] Please remember to provide a detailed step by step description on how to reproduce this and a sample file.
Synje
Offline INNEO_MWo
  • Total likes: 85
« Reply #3 on: June 23, 2021, 11:02:00 pm »
I had this problem in beta phase. I suggest to use the latest full installer setup 10.2.104 and re-install KeyShot. You can also check the graphic driver in case if the OpenGL shader in the split tool window cause the issue.
Good luck!
Hope that helps
CheerEO
P.S. written in short form on a mobile device
Offline jhiker
« Reply #4 on: June 29, 2021, 07:33:29 am »
I didn't have a crash.. but the part I split into two whizzed off somewhere from it's original location and I had to go hunt for it and move it back manually - a bit of a pain, to be honest.
Offline Erik Williams
« Reply #5 on: June 30, 2021, 05:00:05 am »
If you could please send the following information to [email protected], our support team will look into this matter for you:
Computer make and Specs:
        Manufacturer (Dell, Toshiba, HP, etc..)
        Windows/Mac OS version
        Graphics Card model
        Processor model
    Exact KeyShot Version (e.g. 8.1.80)
    CAD Software and version or year (if applicable)
    Step-by-Step instructions to re-create the issue you are seeing
        Open KeyShot scene
        Go to Project, Camera and add a Camera
        etc…
    Screenshot(s) showing the issue that you are seeing
    A .ksp file of your scene
Med Venlig Hilsen / Best Regards,
Erik Williams
Customer Support
