What you should try to do as well is to combine the opacity map with a bump map. You can chose to simply blur the texture slightly and use that as bumpmap, but for more accuracy, select the white or black parts, copy that to a new layer and use an inner or outer glow effect to control the size of the transition. That way you create some curvature in the mesh and you get nice highlights around the openings.
