Author Topic: S24 + Keyshot 10.2 Pro Animation doesn't work at all  (Read 514 times)
Offline Seth Richardson
« on: August 28, 2021, 04:36:20 pm »
create a simple scene in c4d make a sphere animate it.  Send to Keyshot.  Nothing happens, animation shows up but its not actually animated.
Same with camera animation from C4D, the camera snaps to the world 0 position but appears to have the animation.  Camera animation also crashes with a target that is an object.
« Last Edit: August 28, 2021, 04:53:54 pm by Seth Richardson »
Offline Sune
  • Global Moderator
  • Jr. Member
  • Total likes: 9
  • Product Owner - Import, export and plugins
Re: S24 + Keyshot 10.2 Pro Animation doesn't work at all
« Reply #1 on: August 30, 2021, 11:15:24 pm »
Hi Seth,
Unfortunately the C4D plugin does not support deformable animations, so you are limited to transform animations only.
To use deformable animations in KeyShot, you would have to export your scenes from C4D to Alembic and import those in KeyShot.
As for the camera animations, you are completely right, there is an issue there. We will take a look at it.
