Author Topic: Zbrush /bridge and Keyshot import file size problem  (Read 2508 times)
Offline Morgan
« on: October 12, 2021, 05:45:36 am »
Hi there,
I have a problem, I wanted to render and send my work to Keyshot over the bridge and then this is what happens.
File size change ZBrush over the Zbrush Bridge to Keyshot
Zbrush file size = 3,52 GB (3.782.262.664 Bytes)
and after saving as Keyshot .bip
the Keyshot file is increased to = 15,0 GB (16.141.920.999 Bytes) !!!
All the Zbrush subtool tiles are beautiful clean quads, why do Keyshot change the quads in tris when importing over the Bridge
and also increase the file size so much?
If Keyshot triples the file sizes that's also difficult for the decimation master.
Any solutions, that would make me happy.
Thanks,
Offline Erik Williams
Re: Zbrush /bridge and Keyshot import file size problem
« Reply #1 on: October 13, 2021, 12:03:12 am »
Hello Morgan,
While the KeyShot to ZBrush Bridge is managed and maintained by Pixologic, we can take a look and speak with them to help them improve their process.
If you could, please contact our team at [email protected]. Provide them with the version of KeyShot and ZBrush you are using. A representative will send you a link to our WeTransfer Service, where you can upload the ZBrush file and send it to us securely.
Once we have the file, we will reach out to Pixologic and see what we can do to solve this issue for you.
Best Regards,
Erik Williams
Luxion Customer Support
Offline Morgan
« Reply #2 on: October 13, 2021, 01:00:23 am »
Erik Williams, thanks for the quick reply, I will do that.
by the way, I found this post over the change of the mesh when importing, that seems to affect others too, maybe that will help.
https://forum.keyshot.com/index.php?topic=28116.msg117763#msg117763
Best Regards,
Christian
Offline Morgan
« Reply #3 on: November 04, 2021, 02:39:35 am »
As is now certain (pixologic / luxion support) a .ztl file transfer over the Zbrushbridge will increase the Zbrush file (.ztl),
which means that the keyshot working file .bip will be more than 400% larger than before after saving as Keyshot .bip!
Unfortunately this is not mentioned anywhere!
« Reply #4 on: November 05, 2021, 05:58:43 am »
I've been scrubbing through their documentation and you are correct, it does not appear to be mentioned anywhere.
I am sorry for the hassle all of this has caused you.
I suggest reaching out to Pixologic and letting them know that information like this should be documented so that customers know what to expect.
Best Regards,
Erik Williams
Offline Morgan
« Reply #5 on: November 07, 2021, 02:03:31 am »
Hello Eric,
it's ok you just have to know it, I'm just amazed that no one noticed it.  :)
The Pixologic / Luxion Support has been informed over a ticket about this.
Example the org. Zbrush demo head (no uv). to SDiv 7 = 14,582 Mil .ztl = 746,109 KB saved as Keyshot .bip = 1.256202 KB
and when the Dynamic Subdivision is enabled (or forgotten to deactivate) it also increase the number of polygons in Keyshot for rendering.
It is strongly advised that all subtools have to be appropriately scaled down via the Zbrush Decimation Master before exporting or sending to Keyshot.
The Keyshot Mesh Simplification Tool takes too long or destroys the Zbrush UVs, but I didn't have the time in the moment to deal with it,
maybe someone knows the ideal settings.
Best Regards,
Christian
« Last Edit: November 07, 2021, 02:05:31 am by Morgan »
Offline Morgan
« Reply #6 on: January 05, 2022, 04:29:49 am »
@keymanYYZ, no idea what this has to do with the thread?
Offline Morgan
« Reply #7 on: January 05, 2022, 04:31:27 am »
First, Happy New Year to all :-)
With textures, the character would have 18 GB Keyshot compared to 3.95 GB in Zbrush, the problem could only be solved using the Zbrush Decimation Master, the current size of 10 GB (.bip) this size does not cause any major difficulties.
