Problem with shadows on the ground
Started by steef, November 04, 2021, 06:56:44 AM
steef
I've import a model from Substance Painter to Keyshot and apply the exported textured to it.
Once I've applied the textured (.sp from Substance) the shadows on the ground disappear.
I've exported the textures with the Keyshot 9+ preset in Substance
I can't find a solution to avoid this problem, may be one among you could help me out.
That's in advance
Zeltronic
I would Try to unplug the opacity node in the mat graph that most of the time is not necessary.... ;)
steef
Thank you so much Zeltronic, I disabled the OPACITY node and the shadows are back !!!
You helped me out and I really appreciate your answer  :)
