Author Topic: Label Unable To Use Glass Materials?  (Read 2028 times)
Offline bgv2021
« on: December 16, 2021, 09:54:40 am »
Howdy!  I was playing around with trying to use a label and give it a sandblast/etched appearance effect.  I came into difficulty because I can't just add a "frosted glass" material directly to a label.  I can add metals and other materials but it seems glass materials are unable to be dragged onto a label.
Thoughts?  Thanks!
https://ibb.co/vJF4g1t
Offline INNEO_MWo
  • Total likes: 80
Re: Label Unable To Use Glass Materials?
« Reply #1 on: December 16, 2021, 11:32:50 am »
You can use a dielectric material instead of glass and drive the roughness with the graphic. This would solve this case. In older posts we talked about frosted glass with gradient. The forum search should find examples.
Online TGS808
« Reply #2 on: December 16, 2021, 11:34:04 am »
Try the Plastic/Clear/Rough material. That can be added as a label and will give you a similar look to frosted glass.
Offline bgv2021
« Reply #3 on: January 15, 2022, 09:18:46 am »
Thank you!  I regret the delay on my response.  The board never notified me on a response.
I did notice that the clear plastic and white plastic worked better but didn't give that textured/frosted characteristic (like actual etching).
Online TGS808
« Reply #4 on: January 15, 2022, 02:07:18 pm »
I was thinking something like the attached KSP. See if that works.
