KeyShot XR Render in 1 axis
Started by thuy, August 28, 2017, 01:52:58 PM
thuy
Good afternoon,
I was trying to render and interactive model that give the user only 1 direction of rotation just like the rotation of the ring in Keyshot webpage . I tried "Turnable" but doesn't work. Please let me know what setting I can do to get this done?
Thank you so much for your help
What doesn't seem to work? Did you look at the XR in Preview to make sure it looks correct?
thuy
Hi Thomas,
Thank you for your reply. I basically wanted to create an interactive model that can rotate in 1 axis only, just like the ring sample. Do you know what setting should I do to get this effect?
Thanks for your help,
Thuy
Turntable will do that for you. I just tried and it works fine.
