KS3 Image Settings Resolution Problem
Started by ukindler, December 14, 2011, 05:36:08 AM
ukindler
I found another small bug in KS3. It is not possible to set the width of the realtime window in Project -> Settings -> Image Settings to a value smaller than 325. If I enter a value like 137 into this field, it automatically switches back to 325. This problem is caused by the bottom toolbar below the realtime window. If I undock the toolbar an put in on the left or right side of the window, than I can select a smaller width than 325 but now the minimum height is limited. So the only solution so far is to completely undock the toolbar.
Uwe
KeyShot
Thanks. We will fix that. You can still resize the window to get a smaller output window.
