Moving Parts
Started by m2tts, January 18, 2012, 06:15:48 AM
m2tts
I have a subassembly that I have to rotate for a shot. There is no way to pick an axis for rotation, so that when I enter a number in the "x" rotation box under the Position tab, the subassembly rotates under the product. So I go and right click in the model tree and select "Move" and start dragging the subassembly. The translation numbers in the Position dialouge DO NOT update and follow along; so now there is no way to return the sub assembly to it's original position. The same thing happens with using the graphical interface to rotate an object; the numbers in the move dialogs do not follow.
We are aware of thus particular issue and are in the process of addressing it.
