KS2 & 3 fails to start - Win7 x64
Started by Bob, January 20, 2012, 03:42:56 AM
Bob
Hope this is the right forum area!
New workstation, KS2& 3 fresh install goes ok then KS2 & 3 fail to start using Nvidia graphics.
Hardware:
Dell M4600 Precision mobile workstation
8GB Ram
Nvidia 2000M 2GB graphics, & Integrated Intel Graphics
Win7 x64 SP1 on 128GB SSD primary, 750GB sata second hdd
Installed:
keyshot_w64_2.3.2.exe   (-FULLINSTALLER-)
keyshot_w64_3.0.96.exe (-FULLINSTALLER-)
keyshot_w64_3.0.99_update.exe
Startup icons have "Run with Graphics Processor" options on RMB to run with "Integrated Graphics" or "High-performance Nvidia processor"
Not seen this before so I'm assuming this is a Win7/Dell/Nvidia hardware concoction.
V2 Keyshot.exe will not start, except very very occasionally, when "Nvidia 2000M" is selected as the "run with" graphics device
V2 Keyshot.exe will always start when "Integrated Graphics" is selected as the "run with" graphics device
V3 Keyshot3.exe will not start when "Nvidia 2000M" is selected as the "run with" graphics device
V3 Keyshot3.exe will always start when "Integrated Graphics" is selected as the "run with" graphics device
Not sure if this is going to be an issue for the user yet - still in my hands for setting up.
Crash Reports below, similar for both V2 & V3
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   keyshot3.exe
  Application Version:   0.0.0.0
  Application Timestamp:   4f154452
  Fault Module Name:   igd10umd64.dll_unloaded
  Fault Module Version:   0.0.0.0
  Fault Module Timestamp:   4df25d08
  Exception Code:   c0000005
  Exception Offset:   000007fef1cb53e0
  OS Version:   6.1.7601.2.1.0.256.48
  Locale ID:   2057
  Additional Information 1:   581e
  Additional Information 2:   581ee8acabc9f34eead0f4d1eb4ede4d
  Additional Information 3:   39d1
  Additional Information 4:   39d155e915b4afb6c694c4e627440544
Problem signature:
  Application Name:   keyshot.exe
  Application Timestamp:   4df9b469
  Fault Module Name:   ntdll.dll
  Fault Module Version:   6.1.7601.17725
  Fault Module Timestamp:   4ec4aa8e
  Exception Offset:   000000000001924d
  Locale ID:   2057
  Additional Information 1:   c0c3
  Additional Information 2:   c0c3704032ddb179eca60a197907a52c
  Additional Information 3:   edf1
  Additional Information 4:   edf1d5c5cb64fe51600eb59a23a73bcc
V2 & V3 upgrade licensing has been successful after getting KS running using the integrated graphics option.
Not yet tried tweaking the Nvidia settings - hoping for some help in that area if it's appropriate.
Currently have KS V2 running successfully with NO similar issues on a Dell M6300, Win7 x64 SP1, Nvidia FX3500M, 4GB
(And no issues on other Dell units - M90 WinXPx32, 490 WinXPx32, T7400 WinXPx32, T7500 WinXPx32 Win7x64)
Would appreciate any thoughts on this issue........thanks
Since KeyShot utilizes the CPU and not the GPU, then pointing to the Integrated graphics is the way to go in this case.
Just make sure that you have openGL 2.x or higher installed.
