Author Topic: non proportionally scale texture bump in KS3 ?  (Read 3582 times)
Offline Tim Wolf
« on: February 03, 2012, 03:19:20 am »
In KS2 there was the possibility to scale an texture bump just in one direction only, or lock the aspect ratio.
In KS3 so far I can only find the scale function that scales proportionally (locks the aspect ratio).
I already have tried the box map "mapping tool", but this is very hard to handle for scaling since the map will start moving during scaling.
Is there in KS3 a more easy way to scale bump maps in single direction only ?
Offline Chad Holton
Re: non proportionally scale texture bump in KS3 ?
« Reply #1 on: February 03, 2012, 04:49:44 am »
Hi Tim,
Yes, there's a little arrow beside "Scale" under the texture tab. Click this arrow and you will be able to scale in one direction.
Offline Tim Wolf
« Reply #2 on: February 03, 2012, 05:28:25 am »
Hi Chad,
Thanks for your quick reply !
Problem solved  :)
