Persistant Timeline Settings
Started by Ed, February 04, 2012, 09:18:39 AM
Ed
Timeline settings appear to default to 25 FPS.  If I use 30 FPS for example, the setting returns to 25 next time I open the project.
This is an issue when doing multiple animation passes and you assume the setting remained where last set when the project was saved.
Same for the Samples per frame setting under animation quality.  If a BIP is re-opened and re-rendered, you currently have to remember to change this setting in order to match your previous render.
I would like the FPS and Samples per Frame quality to remain where set when the file was last saved, or better yet, add a Preferences option for your default FPS.  My guess is that folks making animations would tend to use the same FPS for all their projects.
Ed
