Author Topic: Keyshot 3 plugin sketch up  (Read 9115 times)
Offline jbomb
« on: March 08, 2012, 08:33:13 pm »
Seems to make sketch up extremely unstable and crashes a lot.
When importing model into 3 it randomly decides to leave elements of the model out of the importing process, changes every time with each import but can't get complete model to transfer.
Works if I export through 2 then open the 2 file in 3!
Any ideas?
  • Guest
Re: Keyshot 3 plugin sketch up
« Reply #1 on: March 09, 2012, 06:09:03 am »
Do you have an example that you can share so our dev team can take a look?
Offline jbomb
« Reply #2 on: March 13, 2012, 04:03:50 am »
I will send something over.
One of the biggest problems I have though is that the plug in makes Sketchup totally unstable. The software crashes all the time when doing general modelling. Once I removed the plugin it went back to normal.
I have Keyshot 2 Plug in installed also, do you think they could be conflicting?
