KS3.1 bug
Started by PhilippeV8, March 22, 2012, 06:33:34 AM
PhilippeV8
Here's what's bugging me lately  :P
In KS3.1.26, material window, the numerical values for scale and shift and angle show a , sign as separation mark.  When you type in e.g. 0,500 it doesn't change anything .. what I gotta type is 0.500, then it changes and it keeps the .
Can we have . everywhere by default ?  Or an option in the pref window which lets you chose between . or ,
KeyShot
This depends on your locale language setup. If you set English as the language then a . will become the floating point separator.
We fixed this in 3.1.48 - it will now respect the regional settings.
PhilippeV8
PhilippeV8
1 more:
When you aply to your part a Metal/Alu/Mesh material, then change its Color propertie, it resets the bump and opacity scale settings and the Type.
Yes - but only if you don't adjust the scale first. This is identified and will be fixed in the next update.
