3 cheers for opacity maps
Started by PhilippeV8, April 03, 2012, 04:19:38 AM
PhilippeV8
You bet, this would've been a BIG file to import/render ...
PhilippeV8
... it looks even better if you don't forget to orient your box for the mapping correctly ......  ???
caden2010
These look brilliant.
Love the rockwool inner as well. Looks more like a photo than a rendering!
Stuart
Pedro_Julio
Yeah, I was going to ask about that inner portion.  Is that a texture or a decal?  Either way, it was a nice touch to make each one look different from the next.
feher
Now that's the ticket ! Nice work as always.
Tim
bobr2000
It's relay awesome!
I also want to ask about inner material.
PhilippeV8
Innermaterial is rockwool ... I took a good res picture of a board here at work ... the inner parts were bright yellow when importing the louvre as a 3DS file.  I just asigned the texture to the yellow material and let the color bleed a bit trough so that I have control over hue/saturation/brightness of it.  Then I just scaled it a bit larger than what you see ... so it's just 1 texture over the whole bunch with a boxmap setting.  Nothing fancy.
Ow and I did add the same jpg as bumpmap to it ... just for a little extra depth.
fario
Josh3D
Philippe was kind enough to fill us in on how he went about creating this. We've posted it on the blog along with the .ksp he provided for the Rockwool material. Thanks again Philippe!
http://blog.keyshot.com/how-to-use-opacity-maps-in-keyshot/
