Keyshot 2.3 on MacBookPro so slow !!!
Started by vstom, April 11, 2012, 01:13:25 PM
vstom
hello there,
can you help me telling me why keyshot  is running so slow !!??!
"render in minutes"  .... not for me, I would say hours !
MacBook Pro
  model :   MacBookPro8,2
  proc :   Intel Core i7
  speed :   2,2 GHz
  number of cpus :   1 quadcore
  Memory :   8 Go 1333 MHz  DDR3
image resolution 1600x900
Render quality : normal
indirect illumination ON
Samples 36
Ray bounces 8
Anti aliasing 4
shadow quality 5
global illumination quality 3
pixel filter size 1.5
DOF quality 2
Sharp shadows ON
This is renderings for interior lighting, with light material.
I can decrease the quality if needed ....
any idea ?
The rendering it taking longer due to the high settings.
Do you need anti-aliasing at 4?
Do you need a shadow quality of 5?
Do you need GI quality at 3?
All this adds to render times. Have you tried default settings?
vstom
actually I can't remember the default settings ...
I need to have realistic renders, I use transparency for the glass of the light, the indirecte illumination.
Can you tell me what settings would you set ?
thanks in advance
This doesn't mean that you need to crank up your render settings like that.
I can't make recommendations since I don't know what the scene is. Can you share the scene so we can take a look at what you are trying to render?
vstom
ho, it changed my life !!
you were so damn right about the settings!!!
I don't know why I set them up so high, it so much faster now !!
Thank you so much for your advice :)
