Keyshot crash on Mac
Started by yucca, June 22, 2012, 03:17:52 PM
yucca
I've a serious problem with keyshot on Mac, it run perfectly, but i can't see real-time render. This is what I see :
[url=http://www.hiboox.fr/go/images/informatique/capture-d
Can you repost the link? Plus you said it is a crash? Is it a crash or a dark realtime window.
yucca
it's dark realtime window, nothing move, like bug, but all Keyshot run, setting and final render
yucca
I'm working on Macbook Pro 13" OS Lion; 2,7 GHz Intel Core I7; Mem 4go 1333 MHz DDR3.
I've done all updates but nothing change.
Wasn't able to get your link to work. If you open your library, does it show thumbnails of the environments (under the environment tab)?
yucca
http://imageshack.us/photo/my-images/10/capturedcran20120623001.png/
All fonctionnalities of keyshot work, juste, I can't see realtime render...
Make sure that your content is installed, located under ~Library/Application Support/KeyShot 3.
yucca
All is installed in the good foldier
yucca
I've find a part of the solution : I've installed Keyshot 3.1.48. The problem appear when I increase the size of the window, so I can't work in full size :'(
