Saving material (library) in Keyshot
Started by Public, June 07, 2010, 05:40:24 AM
Public
When using hypershot it was possible to save an adjusted material in a (new) material group. When you then saved the library the material could be used everytime Hypershot started.
In Keyshot I tried to save a material the same way; first saving the material in a group and then saving the material library. But when I start up Keyshot again the new material is gone.
Can somebody help me to solve this problem?
thanks!
JTrusty
QuoteBut when I start up Keyshot again the new material is gone.
Did you happen to name the new material with the same name as the old material? I noticed that Keyshot won't display materials with duplicate names. They are still saved, and you can check this by opening up your material group in a text editor. I would recommend EditPad Lite. Its free and won't corrupt the file.
Also make sure that your resources folder is not write protected. I have seen this issue in the past.
Thomas
Public
Thanks for your answers. Unfortunately it does not solve the problem yet.
I checked and the material library folder is not write protected. Also I didn't use the same name for the material.
I also tried saving the material in a new material group. But the next time I start up Keyshot the new material group doesn't exist at all.
Does anybody know how to solve this problem?
You are running a fully licensed version of KeyShot, not the demo version?
