Author Topic: Galvanized coating  (Read 10055 times)
Offline DriesV
  • Administrator
  • Total likes: 75
Galvanized coating
« on: November 08, 2012, 04:03:15 am »
Hi
I share with you my galvanized coating material.
It was set up rather quickly for a quick render, but I think the material is rather effective.
The textures are there. So have fun tweaking them in Photoshop, KeyShot.  ;)
greetings,
« Last Edit: November 08, 2012, 04:05:11 am by DriesV »
Offline PhilippeV8
Re: Galvanized coating
« Reply #1 on: November 08, 2012, 04:12:16 am »
Muchos Gracias !
I was missing a good galva material in my library !!!
Offline PhilippeV8
« Reply #2 on: November 08, 2012, 04:20:15 am »
Thank you also for this very neat trick with the ground plane ... (Radial gradient opacity map on an imported ground panel geometry) ... Simple but effective .. and I hadn't thought if that before.
Offline DriesV
  • Administrator
  • Total likes: 75
« Reply #3 on: November 08, 2012, 04:26:27 am »
By sharing we can do more!
"We are greater than the sum of our individual ambitions..."
...Where have I heard that before?
Offline PhilippeV8
« Reply #4 on: November 08, 2012, 04:29:16 am »
itwaznme
« Reply #5 on: November 08, 2012, 06:13:36 am »
Also - can you share the .kmp file? Export the material from the library. Then people will have the material, and not just the texture.
Thanks so much!!
Offline DriesV
  • Administrator
  • Total likes: 75
« Reply #6 on: November 08, 2012, 06:22:37 am »
Here's the .kmp file.
« Reply #7 on: November 08, 2012, 06:44:09 am »
Super - thank you!!
