Main Menu
Galvanized coating
Started by DriesV, November 08, 2012, 04:03:15 AM
DriesV
Hi
I share with you my galvanized coating material.
It was set up rather quickly for a quick render, but I think the material is rather effective.
The textures are there. So have fun tweaking them in Photoshop, KeyShot.  ;)
greetings,
PhilippeV8
Muchos Gracias !
I was missing a good galva material in my library !!!
PhilippeV8
Thank you also for this very neat trick with the ground plane ... (Radial gradient opacity map on an imported ground panel geometry) ... Simple but effective .. and I hadn't thought if that before.
DriesV
By sharing we can do more!
"We are greater than the sum of our individual ambitions..."
...Where have I heard that before?
PhilippeV8
Also - can you share the .kmp file? Export the material from the library. Then people will have the material, and not just the texture.
Thanks so much!!
DriesV
Here's the .kmp file.
