KS3.3.31 > HDR Editor "save as" doesn't save at all ...
Started by PhilippeV8, March 14, 2013, 05:30:06 AM
PhilippeV8
I'm trying to edit Alaskan_Forest.hdz with the ditor.  I've got Hue and Saturation values changed.  Then I hit "save as" and give it a different file name.  It looks as if it worked and I can go back to closing the editor and get on with my work.  Then I close KS or the file, it prompts me that the environement needs to be saved.  So I hit save .. which gave me a crash.
When looking manualy in the folder where the hdz should be, it's nowhere to be seen.
PhilippeV8
Can someone upload Alaska_Forest with 0.2 hue and 160 saturation ?
You do realize that you are not even using the latest version of KeyShot 3? 3.3.33 is the latest and may have a fix for this. I am pretty positive.
PhilippeV8
Yes I do !  Unfortunately ...  ???
I need KS4 installed + KS3 updated to 3.3.33 indeed ... I guess it's on the IT-list ....  ;)
I'll try to bump it up higher on the list tomorrow.
Robb63
I can confirm that 3.3.33 did fix this issue, as I was having the same problem a while ago.
PhilippeV8
Quote from: Robb63 on March 14, 2013, 11:57:36 AM
Excellent  ;D
PhilippeV8
I still have this problem with both KS3.3.33 and KS4.0.74  ???
