decal color not coming through
Started by J.B., March 19, 2013, 06:49:19 PM
J.B.
Hi This is my first time trying to put on a decal for a customer and not just for fun. I applied the image (.png) to the material as a bumpmap and tried all the settings. I can get it positioned correctly, but not to be anything but black and white. (the colors won't come through) I need these colors to come through for it to look like the actual unit is turned on and "displaying" this image. What settings do I have incorrect?
Thanks in advance for any and all help.
I am using Keyshot HD V1.9 64 bit.
Here is the image with color....
Here is my screenshot...
PhilippeV8
I can't see your images (got a nasty web-filtere here at work) ... If you upload them to the forum directly I can see them all.
Either way, so you aply a decal to the bump-map ??  Why ?
You should go to the "label" tab (next to the texture tab) and put your decal in there.
Esben Oxholm
#2
You should, as PhilippeV8 states, apply it as a label and not a bumbmap.
Check out this tutorial: http://www.youtube.com/v/gn6b0nHkvPo
J.B.
#3
Remember, I am using Keyshot V1.9 (see my first post)
I do not see any Label tab in this version.
Philippe - I uploaded the images now. Hopefully you can see them now.
Thank you.
You will need to apply the graphic as a texture.
And why are you still on 1.9? It is time to upgrade!
J.B.
Well, Version 1.9 still does all I need it to do. Sure, the newer versions can do more, but what I need and what I want are two different things. This year I invested in a 3D scanning endeavor and so maybe next year will be the year for the Keyshot upgrade? (unless of course things go exceedingky well this year and upgrading comes early ;) )
J.B.
Thank you! Got it to work as a texture.
even in version 1.9 this software still rocks.
