Author Topic: Data import tutorial does not match Keyshot data import  (Read 3657 times)
Offline jeffw
« on: April 11, 2013, 09:59:24 am »
I am going through the online Keyshot 4 tutorial lessons. Lesson 4 "Data import" shows an import dialog box that does not match the actual Keyshot 4 as can be seen here. The tutorial shows an "adjust environment to fit geometry" but there is no option for this in my import options. What gives?
Offline jeffw
Re: Data import tutorial does not match Keyshot data import
« Reply #1 on: April 11, 2013, 10:38:58 am »
Ok, I think I found the problem here. I have a blank template that I use because it has the setting I like. I made the template by deleting the geometry. Keyshot seems to remember that there was previous geometry and give a different import dialog box for it. I tried the import with a new KS document and got the dialog box that is seen in the tutorial. I guess there is no way to make a template file and get the first time import dialog box. On to the next thing.
