Metal stuff
Started by DriesV, April 30, 2013, 05:37:06 AM
Quote from: The Metal Master on May 14, 2013, 02:47:29 PM
Dries, if the .ksp uses the bump map that was in the file that I sent you only, then I don't want it sharing. If it includes one that was derived from the diffuse or the bump map that was included with package that I shared publicly then that's fine...
J
I indeed derived the bump map from the diffuse map.
Thanks for clarifying, John! ;)
Despot
Unless they have been reduced im size Thomas, the original maps were 2048 x 2048 at 72dpi...
J
rolfomedia
Hi Dries, How are you?
I need a tutorial to make this bucket. The help is very important for my work.
Rolfo
Quote from: DriesV on April 30, 2013, 11:14:34 AM
Thanks, Aldo.
Btw, anyone out there with a good textured material for galvanized coatings (hot-dip and/or electroplated) WITHOUT the typical spangle (crystal-like flaking)? ::)
Something like this:
guest86567
Amazing hard surface work Dries, looking forward to the day when you build a mech!  ;D
