Author Topic: Impossible to import alias File  (Read 10731 times)
Offline davifigo
« on: May 14, 2013, 02:27:06 am »
Since when I install keyshot.. it's impossibile to load WIRE extension.
Alias is already install on my machine.. the 2013 alias surface.... but nothing...
Already ttry to reinstall so many times...
Some suggestion?! Thaks, Davide
Re: Impossible to import alias File
« Reply #1 on: May 14, 2013, 02:03:39 pm »
What version of KeyShot are you running? And where is ALIAS installed?
Offline noeudpap
« Reply #2 on: July 22, 2013, 02:09:39 am »
I'm running the keyshot trial and alias 2013 and get the same problem...
« Reply #3 on: July 22, 2013, 06:07:23 am »
Make sure that ALIAS and KeyShot are installed on the same drive/partition so KeyShot can find ALIAS.
Offline toldex
« Reply #4 on: October 02, 2013, 06:27:52 pm »
I have kind of the same issue. Running alias 2011 and keyshot 3.3.33 demo on same partition (mac pro). I cant load an alias wire file, i dont understand. Please solution thanks
Offline Chad Holton
« Reply #5 on: October 03, 2013, 05:27:17 am »
How long you been running that demo? We have a much newer version: http://keyshot.com/try/
Try it out and if you still have an issue, please send your Alias file to [email protected]
Thanks,
Chad
Offline kain.shao
« Reply #6 on: October 12, 2013, 11:23:09 am »
I have the same problem. I cannot import any .wire file. I have reinstalled osx and keyshot(4.0.37), but still the same problem. Have you solved your problem? If yes, how?
thomasteger
« Reply #7 on: October 13, 2013, 08:05:58 am »
First of all you should be using 4.2.35. Second, please make sure that ALIAS is installed. KeyShot supports ALIAS 2010 and later, including ALIAS 2014. Works perfectly on Windows and Mac.
