New issue needing help
Started by dnelson, July 15, 2010, 10:27:29 AM
dnelson
I'm trying out the keyshot 2 demo.  (KeyShot 1 was a bust because it wouldn't render my bigger files.  Now I'm having license issues on 2...)
Keyshot 2 will import my STP files, but it will change the part sometimes.
Here is a coupling, BIP format
And here it is in STP
So easy fix right?  use BIP.  well thats part of a larger assembly.
The larger file imports alright in STP format, but has the part malformed
When i try to import the same assembly in BIP, I get a "Can Not Parse xxxx.bip" error notice.
So whats the fix?
Ralf-S
With what application you create your STEP files?
dnelson
Alibre Pro 12.1 (most recent upgrade w/ keyshot 2 export )
Ralf-S
#3
So easy fix right?
So whats the fix?
I would send the Alibre file to: support @ alibre.com
dnelson
Quote from: Ralf-S on July 19, 2010, 06:51:43 AM
So easy fix right?
So whats the fix?
The easy fix would be to use BIP export.  that's the whole reason for alibre upgrade.  But with my larger file only the stp (which renders wrong) will import into keyshot.  The BIP on larger files has a Parse error.
I tried contacting Alibre support, they don't reply, even the so called live support is never online.  It's kinda stupid I paid for the maintenance package to have such support.  Other then to have keyshot 2.  Which I got screwed on the license for.
This forum seems the only place i can get response.  (KeyShot support doesn't reply to emails either)
Ralf-S
I think it's a problem with the generated native CAD "geometry".
Please take a look: http://forum.alibre.com/
There you can post your native Alibre file and a lot of "experienced" Alibre users can help. ;)
dnelson
my file is large assembly composed of many other assemblies and muany more parts, too much to post
Ralf-S
Quote from: dnelson on July 19, 2010, 09:01:42 AM
Your file shown above is sufficient to check, probably no larger than a few, 3-4 MB. (*.zip or 7.z)
dnelson
well that was only one part tho...   this parsing error is in the larger file, if i send an assembly i have to send all the containing parts right?
Max
QuoteI tried contacting Alibre support, they don't reply, even the so called live support is never online.  It's kinda stupid I paid for the maintenance package to have such support.
Not sure what you are referring to because our records show that we've responded to each of your cases over the last few months. I do not show a case for you contacting us regarding a parsing issue, or any BIP issue for that matter.
The BIP Exporter in Alibre Design uses the exact geometry on the screen - what you see is what you get. Unlike the STEP translator, which can occasionally change the geometry around. The problem is likely on the KeyShot end, but could possibly be on the Alibre end as well. Step 1 would be to send us your file, through Support.
Max @ Alibre
dnelson
The last 5 times i tried on line "live" support the was no rep on the other end.  I don't even bother now.  As far as email, I've only emailed for billing questions.  Because I've found in the past it takes too long to get responses by email, technical or otherwise, and usually I don't have time to wait on a response for technical help, If live support is down, I go to web for faq's and forums, or try to fix the problem myself, or try 30 other ways to do the same thing till one works.
And no, you didn't get word from me on parsing or BIP issues, i came here first, figuring it was a Keyshot issue not alibre.  I probably would hit up the alibre forum next.
Even though getting technical help / customer service is a frustrating process, It's not my real issue...
http://www.purdybilt.com/2in Coupling.AD_PRT
That's the part above.  If you can figure out why it distorts in a STP file, then I can probably utilize the larger project with STP because keyshot will import the STP.
But fixing that (or if there is no fix) won't solve the parsing error with the larger BIP file (if it's even a size issue).  However, that set of files is proprietary, I can't post that on the forum.  Is there an address I can send the files directly to?
Quote from: Max on July 19, 2010, 10:55:18 AM
Max @ Alibre
Ralf-S
#11
- Download your file.
- Saved
- Open your file with Alibre V12.1 ( current version)
- Export -> *.bip
- Open with KS V 2.0.46
- No problem
Snapshot -> 20 sec.
*.bip file as att.
dnelson
Ralf-S
You mean STEP (AP 203 / 214) or *.stp ?
dnelson
Quote from: Ralf-S on July 19, 2010, 01:16:36 PM
I don't think it matters, i think the same error occurs, in Alibre Step, AP203 or AP 214...
But I usually use 214.
